nightflyer
Colleyville, TX
I’m curious to see if anyone else has noticed a trend in their oil analysis and sticking exhaust valves. I would occasionally get a slight shutter during cruise ever since my trip to Idaho in May. I just thought the engine was digesting some water since I had pulled a small amount of water out of the fuel tank when I sumped it during preflight. I only pulled water out once though. I just did a trip to Utah last month and I was getting some morning sickness on the first start-up and that was the first time I’d had any issues on start up. I was probably in denial but I attributed it to the high altitude and cold weather. I had a couple of more shutters on the last leg home and then the the valve finally stuck for good on the first start up after my trip when I went to warm up the oil for an oil change. I certainly learned some lessons with what a sticking exhaust valve feels like now. My oil analysis had been showing high chrome which initially we thought was because the engine sat for five years during restoration and had some corrosion but it got worse as I ran the engine. I’ve attached my latest oil analysis to see if anyone has any ideas if there were clues to my sticking valve from that. It was the number 3 cylinder on a O-320A2B 160hp. I use Phillips XC 20W50 with Camguard, and I don’t used MMO in the fuel or oil. The engine was built in 1982, had 1600 hours on it, and was never overhauled. It’s now at LyCon getting getting it’s long awaited overhaul. Don’t be like me and let it get this far when you get morning sickness. I’m extremely fortunate that the valve decided to stick for good after I got home and not on my trip.
