For you engine gear heads, I’ve developed a pretty good oil consumption problem. I’ll try to set it up:
A second run o-320 A2B, 160hp. Has approximately 1500+ SMOH, about 1200 on the cylinders. I’ve gone from 1qt/10 hrs to 1qt/4-5 hrs. Went into annual and we started looking for all the obvious culprits. All cylinders were high 70’s on compression, stared looking with bore-a-scope and all we could find was #4 had some oil in the cylinder. We pulled #4 and found that both oil rings were stuck. Top compression ring appears ok. Decided since 4 was off we’d pull #2. Rings weren’t stuck but gummy. Bother cylinders exhaust valve and guide were worn. #3 was removed about 300hrs ago and valve and guide were replaced due to low compression. #1 has never been off but we see no problem in compression or in the scope. Both cylinders went to cylinder shop, valves and guides replaced but they would not hone the cylinders because they were nickel. (Don’t know what that had to do)…cylinders went back on with new oil rings. After 8hrs of 2400-2500rpm on 1-2 hr legs I’m still at 1qt/4-5 hrs. My question is: will the new rings never seat because of not honing or am I just not being patient enough. EGT/CYL.Head temp are not hot! 1320/350 on #4. I do not want to top on this engine, new cylinders are extinct anyway, and I have a new O320-B2B on order. How screwed am I?
