As Mr Spock would say. "Illogical!"I don't understand why a Lansair IVP can fly in the airspace with the experimental version but I have to pay extra money for the certified version in my Super Cub or wife's Tri-Pacer. I have asked myself what are the ramifications if I install as a minor modification?
Those events (sunNfun & Osh) require you to turn off your transponder.
I went back and looked further at the Navworx ADS600-EXP. It does have an option of also receiving 1090 with a hardware addition and a future software update. It also specifies for experimental and LSA only. That could be a problem which I have no issues with installing in my plane but if I were to sell it, then what? Web and Steve Pierce how do we overcome this issue paperwork wise? I'd like to keep it legal.
If it's good enough for experimental, how does any other ADS-B transceiver know what certification basis the airplane in which it is mounted is? A radio wave is a radio wave.
I found it. I got the two model numbers mixed up. The certified unit is a base price of $1999. Not too bad. The experimental is $1399. Back to the drawing board.Since Navworx has a certified version for not much more money, I wouldn't expect to get the EXP approved.
I've been following this thread with interest and am holding off on doing anything yet. I do occasionally fly into a Class C airport and less occasionally under a Class B.
I'm wondering if a transponder will still be required in this airspace after 2020?
I'm wondering if someone could explain how the UAT Out system works? I understand Out through a ES transponder but the UAT Out isn't clear to me. I realize that a WAAS GPS is needed but I've read somewhere that a Mode C transponder could be linked with the approved GPS and work as an Out solution. Is this correct?
In a nutshell, ADS-B out is a transponder signal, with an ID and position signal 'piggy backing' out of the same antenna. If you have a transponder with RS-232 data lines, you can PROBABLY (some will work, some will not) build an ADS-B out system with it. Connect the UAT box to the transponder via the 232 lines and connect a WAAS enable GPS signal to the UAT via 232 or 429 data lines. Some UAT boxes have a WAAS GPS built in to simplify installation.
When the ADS-b signal is called for, The GPS sends the location fix to the UAT box, which sends that location and an aircraft ID to the transponder, which sends all this information out the antenna.
Yes, that is some of what is confusing me. If I installed the GTX 335 and got the WAAS enabled GPS position from either my Aera 660 or the GDL 39 3D, is that possible and does it meet the requirements?
"In the Cessna I'm installing a Garmin GTX 335 as the Out."
spinner2, Which model of the 335 are you installing? Do you have to use the one with the GPS to be legal?
I'm having a bit of trouble understanding all the details of the requirements.
