BENEFACTOR
Broken down and rebuilt a lot of wings from the mid 1940s and up and have never seen corrosion issues with the stainless fittings. The fittings that attach the drag/anti-drag wires to the spar are pretty malleable and can be adjusted if you get the wrong one in the outboard bay where the wires are longer. 4130 is harder and I guess my concern would be vibration and cracking at the corners. I am not an engineer and respect what Piper did, the robustness and longevity of the design. I would do some serious calculating before I changed a major structural component.
