WindOnHisNose
BENEFACTOR
Lino Lakes MN (MY18)
OK, now that I have the mags redone, new spark plugs and all...and another problem has surfaced.
When I apply carb heat on initial runup I get a 400 rpm drop and the engine runs really rough. I have noticed this over the course of the last few months. This happens when the engine is cold, but gets even worse when it is warm. I noticed this this morning when I was leaving ANE for Duluth, but the runup was otherwise uneventful.
I decided to pull the carb heat on when I was in cruise and the engine ran extremely rough, and it didn't get better with time (I have experienced carb ice in the past with other carburated aircraft, with the rpm dropping, then rising...this time no rise was noted).
Of note was an experience when flying back from Ely and the Fall Colors Tour....I was paged to call the ER while in flight, so I landed at Cloquet and didn't dare shut down the engine, so I pulled onto the grass to speak with the ER physicians about my patient. After completing that call I checked for traffic and pulled onto the runway, gave er full throttle and the engine was running so rough I aborted the takeoff, ran up the engine (wouldn't go up to 1700 rpm), leaned it out to clear the plugs (I thought) and tried the runup again. Again, really rough running engine, couldn't get up to even 1400 rpm, so I taxied onto the ramp and looked things over and discovered my carb heat was full on. Felt stupid (I had left the carb heat on upon landing), pushed in the carb heat and ran it up. Ran perfectly well, I flew home without problems.
I inspected the lever and cable from the carb heat control and the arm which moves the carb heat flap and it moves full travel.
Any suggestions or explanations? I am going to ask Larry Cassem to take a look this weekend, and am a bit nervous about the flight home tomorrow...will leave the danged carb heat lever alone until I get this figured out.
Thanks.
Randy
Thanks.
Randy
