Bugs66
Spokane WA
I have around 20 hours on my experimental now and love flying the plane. One area I am focusing on now is stablizer buffeting. During landing approach when I pop my 2nd of 3 notch of flaps, I feel aerodynamic buffeting. My approaches are usually 55-60mph for routine landings on pavement. I would classify it as light buffeting. The final notch of flaps increases the buffeting slightly. The buffeting is coming from the stablizer because when I look back at the stabs I can see the buffet. When I get to flare the buffet disappears. At no time do I feel I don't have elevator authority. I have VG's on wing and under tail.
I have read some of the older posts of extended flaps causing buffeting. I have extended however not all the way to the fuselage and have about a 3" fairing.
Here are some other considerations:
- I have 84" prop
- 180hp with 0 degree thrust.
- I don't run flap gap seals
- I don't have tail shake on the ground, nor in climb or level flight.
My tail brace wires feel pretty good but might tighten a bit.
I would be curious and appreciate any comments anyone has with similar setups (extended flaps, etc.). I read that perhaps the BLR strakes might help in this area. Looking for a remedy.
- I have 84" prop
