mike mcs repair
Mike, show us how to make color matched gap seals out of that stuff.
little different stuff... foam rubber casting
thats silicone.... heavy/solid... foam would be lighter & more appropriate I bet...What about the blue stuff your making the mold with?
Mike, I am really enjoying this thread. Thanks for starting and regularly contributing to it.
Mike, since you're big into making stuff, how would make a lower lip for a cowl. I'v tried a couple ways and can't get it right. I have a small lip on it now but need to make a bigger one, or buy one (2+2)
Steve, you realize that Timmy is now texting Tom. Goes something like this. Tom, Pierce had a good idea, as long as your already there can you........................................
I don't have friends like that.
Ummmmmm. let me count the ways. skis, 180..............................................................................................
Or bushwheels that go flat. .
Used to locate pre-drilled holes in the wing ribs, fuel tank covers, panels, skin. Pre-drill the ribs, screw in the back markers, lay the skin sheet over the top, tap with hammer, turn the sheet over, and drill the holes. This is especially useful for rivnut installation.Due to the large size of the hole required, small errors in location can lead to the "Oh darn, I missed the rib syndrome". Backmarkers save you hours of frustration. 2 sizes of threaded backmarkers are available. We recommend using the 04-00131 for wing ribs. Drilling the wing ribs with a 3/32" drill. Drop in the back markers.
Mark the skin by taping with a soft hammer. Turn the skin over and drill the skin with a 3/32" drill. Cleco the skin into position enlarge the holes with #30 drill & cleco. Now you are ready to rivet.
*THESE BACKMARKERS ARE RIBBED (THREADED). OTHERS ARE PLAIN.
new arrivals from ATS, could have used these many times in the past!!
washer holder
bolt holder
Got a link?
