wacodriver
MEMBER
Rastede, Germany
Just anothern option
[h=1]MT Propeller[/h]
[h=2]Electric variable pitch propeller for Piper PA-18 series[/h] Atting, July 2018. MT-Propeller Entwicklung GmbH has received the LBA STC No. SA 1479 for the installation of the 2-blade electric variable pitch propeller MTV-17-C/188-53 on the Piper PA-18 series powered by the Lycoming O-320 engine.
MT-Propeller brings an eectric variable pitch propeller for the Piper PA-18 series to market
MT-Propeller President Gerd Mühlbauer says, that the installation feature the following advantages:
- Enhanced climb performance up to approx. 10 % (SL, ISA conditions)
- Take-Off distance over 50 ft obstacle reduced by up to 7 %
- Enhanced cruise performance by up to 5 kts (SL, ISA conditions)
- Some Models comply with the strict German Noise Regulations “Landeplatz Lärmschutz Verordnung” for unrestricted operations in Germany and other European Countries
The MT-Propeller natural composite blades have no life limitation and are repairable in case of an FOD. They also provide best vibration damping characteristics for almost vibration free propeller operation.
About MT-Propeller
MT-Propeller is the world leading natural composite propeller manufacturer with 30 certified propeller models from 2-blade to 7-blade hydraulically controlled variable pitch propeller, for engines producing up to 5000hp, and 2-blade to 4-blade electrically controlled variable pitch propeller, for engines producing up to 350hp as well as two blade fixed pitch propellers.
The high performance, light weight and durable MT-Propellers can be used on aircraft with piston engines and propeller turbines, as well as on airships, wind tunnels or hovercraft. MT-Propellers can be developed for nearly every aircraft type from motor gliders to regional airliners.
Fulfilling the highest certification requirements they are also supplemental type certified on Part 25 aircraft.
MT-Propeller is holder of over 210 STCs worldwide and OEM supplier for more than 90% of the European Aircraft Industry as well as 30% of the US Aircraft Industry. 20,000 propeller systems with more than 70,000 blades are in service. 130 Million fleet hours where already performed on MT-Propellers. 36 years ago, the first MT-Propeller was shipped.
A factory certified network of 62 service centers, provides best service and maintenance all over the world.
MT-PROPELLER Entwicklung GmbH
Airport Straubing-Wallmuehle
D-94348 Atting - Germany
phone: +49-(0)9429-9409-0
fax: +49-(0)9429-8432
sales@mt-propeller.com
www.mt-propeller.com
About MT-Propeller
