BENEFACTOR
Cgoldy
You might check your bungee (spring) setup that runs from the stabilizer to the elevator horn. If you have a chance, compare yours to Martyn’s or another stock cub. Some of the problems I have seen on the X-cubs is that the cable/spring setup is not the proper length or the spring is not the right spring. During your trim operation the spring should never stretch on its own. The only time it should stretch is when you override the trim with your stick. As you trim for nose up slow flight----your elevator should be coming up as the stabilizer is traveling down. If your spring is too weak---your elevator will not come up to the position it should to relieve stick pressure and allow trim for slow flight. There are a lot of weak springs out there. Just a thought and it may not apply to your setup. There is more to all this but too much to write. Good luck---if there is a problem back there I am sure you will find it.
edit: Looked at your pic----you do have the TL built in.
Mark
Mark, are they still paying you a royalty on those mounts?
