Jr.CubBuilder
My plane got a new alternator and motor, now there is a loud buzzing that seems to be in sync with motor RPM only when the field windings for the alternator are on and I push the transmit. When I turn the alternator off via the breaker switch for the field windings there is no buzz when I transmit with the motor running
I previously had an alternator on the previous motor, and origionaly had a generator when I first got the plane. I have never had this problem with either of the previous setups. The intercom and radio have not changed nor has my headset or intercom jack setup, however the mechanic has been rootin around behind the panel.
PM1000 intercom, KX170 Nav/Com
I'm thinking I've got a bad ground, but the buzz is only present when I transmit and the alternator is on. If it were a bad ground to the airframe I would think I'd hear all the time, unless the squelch is filtering out the noise(?)
Any ideas?
So far I haven't had a chance to talk to my old mechanic, the new one seems to think it isn't an issue.
Any ideas?
