Crash
GONE WEST
Nikiski Alaska
Wondering if anyone else out there has had this problem.
I finished my new PA-18 in March with Dakota wings and tanks. I started flying it a lot right from the start. One day after visiting a friend at a cabin I took off and flew a couple of miles on the R.H. tank and the engine quit. I switched to the L.H. tank and it restarted. I looked at the site guage and it had about an inch of fuel showing with the ball floating on top (1/4 tank). I rocked the plane and the ball went up and down but the engine quit when on that tank. I wrote it off as a piece of junk in the lower restricter elbow of the site gauge. Because when I landed the gauge went to empty and it seemed to function right when I put gas back in that tank.
A couple of months later I was in the middle of Cook Inlet on the R.H. tank and the engine quit again. I went to the L.H. tank and it started again, but it still showed 1/4 tank of fuel in the gauge and the ball went up and down when I rocked the plane. This was not funny anymore. I figured the only change I had made in the rebuild was the larger Dakota tanks (should not make a difference) and Atlee Dodge pressure fuel caps as required by the 180 hp STC. I figured it must be the pressure caps holding differential pressure between the tanks and forcing fuel to stay in the site gauge.
I removed them and went to stock caps. It still had the same problem on the R.H. tank with the stock fuel caps but the L.H. gauge worked right.
On my last long trip I went back to the pressure caps to see if I was dreaming. The engine now quits with a 1/4 tanks showing on both tanks.
Whats UP????? Any ideas out there? Crash
