Fortysix12
RanchAero Grand Vista, Brooksville
My plans don't show the false rib under the gas tanks so don't forget it
My plans don't show bracing for the gas tank bay ribs. Need two on the outboard top and four on the bottom. Otherwise the fabric will warp the rib, found out the hard way on one wing. Making a repair now. Covering now and going pretty good. Minimum fasteners on the false spar as well as the flap bay because it's hard to get a good looking job with so many screws. Blow out your wing everywhere because if you don't debris can fall under your leading edge fabric.Ok, I'm a green horn. I hope it fly's.
