KJC
Clear Lake, MN
Its a common problem, but Ive had enough of messing around with this wet compass. Its off again. We tried degausing the airframe and it worked great for about a month of so. Now its off again and no amount of adjustment will fix it. If you remove it from the airplane or at least away from the tubes, it will work fine. Definately some sort of reoccuring magnetic build up.
Ive read some of the threads regarding SIRS compasses and they seem well liked by those who have installed them. Im thinking that this would be a minor modification with a simple log entry.....? ("Removed compass from upper panel and replaced with SIRS compass mounted on windscreen. No W/B change.")
Curious what the other Mechanics think.
