eski said:
My alternator keeps falling off line. It does not matter what the load is. I can bring the alternator back on line by turning offf the master switch for a few seconds. It is a three position switch. Centered it is off, up or down it is on. In flight with the switch off, all components are powered and the voltage is aprox 14.9 volts. In either on position the voltage is 13.9 volts. It stays on line for 10 to 30 minutes. Lately it stays on line shorter. The overvoltage relay has been replaced and I am still troubleshooting. Any suggestions
alt brand(s)??? (alcor/interav/piper, B&C, Plane Power?, ford/cessna?)
amp meter (analog) steady or needle bouncing? (bouncing = bad shorted diode(s))
if its like an interav clean where the regulator red wires hook to and also where the over voltage red wire hooks to, since they may be seeing different voltages..
if its a ford/pestolite style you may have an bad spot on field wire, intermetently grounding of the field wire inside the shield turning alt on(but you would hear allot of static as this happens)
add at temporary ground wire say a #8 from engine case to one of the small #8 studs ON fuselage coming through firewall .... the original grounding method is useless...
also you can hook up a volt meter so you can watch it in flight, and see when it quits, it sounds like the voltage is going high and overvolt is doing its job and tripping....
also do you have access to another battery you can try, sometimes a flaky Cell or a loose plate in it will drive you nuts.... (one cell intermittently dies, regulator sees that volt drop and pours the coal to it and goes too high, hence tripping the over voltage relay)
also keep all expensive stuff (radios & such) off/ breakers pulled till you get this fixed...
