I found a nice set of the old original Federal skis a few years ago and have been using them. It is my understanding that Aero bought out Federal ski,.... they are very similar.
The biggest difference between the modern Areo ski and the older Federal ski is the tunnel/tower width; Federal skis are more heavy duty. Tunnel is wider and longer on the federal's, areo made the newer ones lighter duty....but wider bottoms, which is probably the best deep powder straight ski on the market.
On glarce ice, re-froze overflow, ice ridges and rough stuff the aero ski will not hold up to serious usage, however excellent powder ski.
At any rate, I'm running the 2,500's, which I'm sure are similar to the 2,800.
Some features that I like include they are shorter than Landis skis so you can turn much easier and much sharper....as far as ski turning goes. Lighter than Landis or Dodge skis, easy to fasten the UHMW to bottom, plus they are "banana" shaped front-to-back, and have a convex bottom side-to-side which give great direction control in the power, or hard pack, before the skeg digs in on glare ice. The tower height (axle height off the ground) is as high, or higher, than other skis which puts the plane at an excellent angle....similar to big tires.
Only real draw-back, or learning curve, that I've experinced is getting used to them in DEEP powder. If you're used to running a longer ski and then swtich to these shorter ones, it take a little practice to find the best technique for getting on step in really deep fluff. Because they are so short you kinda have to get on step, just like foats, (pop the flaps hard) in the really deep stuff and then lift one ski off and then the other to get maximum short field take off distance. When working in a tight area you can circle fairly sharp, cause they're short and turn nice, and then carry your mometum forward on your take-off roll.... I can take off much shorter with them versus any other straight ski that I've used.
I can tell you from experince, if you have a strong engine w/ a good prop that will pull hard,....... when you're belly deep, fuselage sitting on belly, rudder is plowing a row, ...and... you have enough room, you can throttle into it and pull the plane out the hole and the skis WILL get the plane back up, on step, and build speed... and take off. No other ski that I've ever used will do that. Prop will chop, chop, chop along when you first get going (snow flying everywhere), and amazingly it don't really hurt it!
