Not sure about model years but the neighbor has a first model year 185 that originally came with an IO-470. That airplane does not have a fuel selector, only a fuel on/off valve. Not an option I would want.
The United States Department of Interior has an excellent inspection manual for the 180/185 airplanes. If you PM me your email, I'll send it to you.
I have the same recollection as Mike. This was an option. I believe it was also included as part of a seaplane kit. Optional otherwise.
I use my fuel selector every flight.Consider this: How often do most Cessna pilots actually select one tank or the other? Certainly, there are reasons to do so, but they're pretty rare when you really need to, and that's usually because your fuel system feeds unevenly. I'd fix that before I added a fuel selector.
Helps stop cross feeding when parked wing high.....drip drip out the fuel vents
Yep, IF you think to switch to L or R or Off when parked.
Every flight in the C-185 ended with the fuel selector not on "Both". Part of my checklist. While in flight the plane I flew the most always fed the right tank first while on "Both" despite repeated efforts to relocate the tank's vent relative to the lift strut. Ball was in the middle and checked against fuselage level while parked.
Hmmmm, Supercub.org to the rescue: https://www.supercub.org/forum/showthread.php?51132-185-Uneven-fuel-usage-from-tanks Too late for me.
When boon docking for several days I kept the fuel selector on the right tank and used it for daily running. Then kept 15 gallons in the left for reserve just in case the bears found my stash. Also it was easier for me to fill from the right side than left - container on engine cover towel, climb gear or steps, swing container to top of wing while holding the float lift ring for support if slippery. The factory caps leaked fuel out and water in so had them replaced with raised caps. That also helped reduce the crossfeed problem when running on Both.
In bear country I anchored 15 gallon plastic drums offshore until needed. Tetlin, Kanuti, and Yukon Flats were bad for bears. Never got water in fuel passed the O-ring caps. Seagull poop on the drums was an issue.
A friend has asked me to cast an eye over a O470 powered Cessna 185. It is NTCA and has been recently refurbed. Any advice on the pitfalls of ownership? I am aware of the wing and tail AD anything else to look out for?
.....In bear country I anchored 15 gallon plastic drums offshore until needed. .....
Me too....I switch it from OFF to BOTH prior to start-up, then at shut-down from BOTH to OFF.
Mine does not cross-feed in the off position.
Mine feeds faster out of the RH tank, occasionally on a trip I will run it on LEFT,
but it has never fed so unevenly as to actually be a problem.
Smart....I probably wouldn't have ever thought of this.
Yes, the fuel cutoff valve was standard on all of these planes. The R/L/Off fuel selector valve was an option. The early 185 I flew had no selector valve, and it was mounted on EDO 2960 floats in summer and straight skis in winter. When I first flew it, I asked the owner of the plane why it didn't have a fuel selector. He had ordered the airplane new from Cessna, and wanted it kept as light as possible, so when he ordered it, he marked the box for fuel selector as "none".
The Cutoff valve is required, since you have to have some means to stop flow of fuel to the engine compartment. Which begs the question:
How many of you Skywagon jocks have actually pulled that cutoff valve and shut off the fuel using it? Good exercise if you haven't.
This was the first model year the IO-520 was standard, and he'd flown that thing a LOT since he bought it. He said in all the years he'd owned it, he'd never wished it had a fuel selector. It was a great airplane, and it was light.
Finally, a fuel selector involves at least three more connections, a valve that can fail/stick, etc. All possible leaks, failure points, etc, though I realize that rarely happens.
Minor point, but “off” crossfeeds just like “both”. Gotta select left or right to prevent cross feeding. Inner spool in the valve has ports forming a “T” shape.Yeah, but bears swim.....a lot. Might be harder for them to wrestle with a jug in the water, but.....we had a cabin on an island, small island. Brown bear lived behind the outhouse when he wasn't fishing in the stream up the lake a ways. Made you certain to announce your approach when headed to the biffy. That bear swam a LOT.
I do not park a plane with the fuel selector in the OFF position. Almost the only time I use that position is if I'm fueling and need to get max fuel in tanks. Prevents fuel from cross feeding, while you're switching sides, and frankly, I'm not sure that's even much.
I religiously check fuel selector on during my pre takeoff flow. That said, I also know I'm not perfect.....Most planes won't let you get to the runway if the selector is off, but not all.....
