Hello, everyone.
I'm fabricing a PA-12, and have run into a problem with its wingtips. The tips are a brand new pair of fibreglass booster tips from CubCrafters (replacements for the booster tips originally fitted on the aircraft in the 1970s), and they are going on aluminum tip ribs.
The booster tips fit perfectly over the ribs if the trailing edge skin is left off, but they will not fit on if the trailing edge skin is attached. The trailing edge skin has a wider radius bend at the trailing edge than the inside of the wingtips, and the skin over the wingtip (by itself) thickens the wing more than the wingtip will tolerate.
My AME and I have come up with a solution: putting the trailing edge skin over the wingtip, and the wingtip over the rib. It's a neater look than putting the trailing edge skin inside the wingtip, and I can put a spacer between the rib and the trailing edge while fabricing.
Does anyone see a problem with this approach? Can you think of a better solution?
Wingtip images at:https://photos.app.goo.gl/bHzoEFTNRQyzwWxp6
