when doing wheel bearings, im just wondering, if anyone is putting the molded seals in or just sticking with the felt? if there cleaned and packed without being around a lot of water, the felt works ok. just need the itch i got, taken away, for that rubber seal. might even be ok just to run the same felt on the inside on the outside. ive got that little 1/4 inch felt with the seal cup 153-01500 which i could take out and change to the same as the inside.
