A few days ago I just made it halfway through my 64th, I at least want this plane to outlast me. Not knowing what my end date is.
Yes the wheels were tight. The two phenolic wheels on the outside should have higher flanges, I did cut them deeper when I saw the flanges start to wrinkle. But it was either too little or too late. I have more material such that I could cut the rollers deeper still and go for it again. Gut feeling is the material is just to stiff for this simple method.
First step is to get time on the Pullmax and see what that does, if the dies will do inside work. I can make an inside die if needed.
Heck I might go downstairs and see if I can grind a groove in my shrinker dies to pass the flange through. I can learn to accept the rough finish since this gets a bottom cap anyway that can hide the tool marks.
