I'm in the process of converting my stock Prosolite starter and Delco Remy generator over to B&C products. I have a front mount Niagara oil cooler so I'm using the required Atlee Dodge mounting brackets. I have a few issues with the install.
1. My starter ring gear pulley size is 7 1/2". The Gates XL 7312 belt that was shipped with the kit from B&C is too short. B&C sells a 7365 belt that is 5 1/2" longer but that would be way to long. Does anyone know which belt is required when using the Atlee brackets?
2. The B&C alternator pulley uses a 3/8" wide belt, but the stock starter ring gear pulley uses a 1/2" belt width. The 3/8" belts fits down in the starter ring gear pulley, but is it okay to run it like that?
3. I currently have flexible oil cooler lines that run on top of the engine. The new B&C starter and alternator are in the way to run my flex hoses through the original holes in the baffle. Do I need to reroute them below the engine or do I just relocate the holes in the baffle and have longer hoses made to go around the alternator and starter? If I keep them on top, does anyone have pictures showing how to route them around the alternator?
