Interesting discussion. I'd pretty much second everything Dave and George have noted about the Husky.
Christina: Here's something to consider--you are sort of correct regarding the published stall speeds of the airplanes, except that you're comparing apples to oranges.
For example, the model A-1 Husky stall speed was published at 43 mph, maximum gross weight (1800 lbs) and power off. The Super Cub, with a max gross weight of 1750 lbs has a published power off stall speed of either 42 or 43 mph, depending on what year you're looking at. That is apples to apples. And, by the way, the A-1 Husky POH also advertises the Gross weight power ON stall speed as 37 mph.
Now, the model A-1B Husky stall speed (power off and at 2000 pounds) is listed as 53 mph.
Let's compare apples to apples, then: the Wipaire converted PA-18 published stall speed at max gross weight (2000 lbs) is given as either 52 or 53 mph, though I don't have a supplement here at the moment.
The CC-18-180 Cub Crafters Top Cub stall speed, at 2300 pounds, is listed as 44 mph. That airplane is equipped with BLR VG kit, from the factory, though. It is a 180 hp, and empty weight of ours is 1307.
In my experience, the Huskys pretty much stall at or below the speeds Aviat gives for them.
As to ailerons, EVERY Husky has more effective ailerons than any STOCK Cub I've ever flown, that is a Cub with stock ailerons and wing length. IF you want really BAD ailerons, fly a Super Cub with extended wings sometime where they didn't extend and move the ailerons. I flew one of those for nearly two thousand hours, and pretty much gave up on ailerons in that cub. But, again, that doesn't represent the great mods that have been done to many Cubs either.
The single biggest issue the Husky has is empty weight. That said, look at an uncovered Husky sometime, and you'll see where the weight comes from--structure. I've seen one that was screwed into the ground, killing the pilot, who wound up with the engine in his lap, but the rear seater didn't get hurt except a concussion from the deceleration.
For many years, I flew Huskys and Cubs, often on the same undercarriages, same model skis, same tires, same floats. I generally found the Huskys to be 20 mph faster than a Cub, while buring 1+ gph LESS gas. These Cubs were all 160 hp cubs with Borer props.
If you have to go out a ways, or stay airborne a long time, the Husky really shines.
I never found the Husky wanting for STOL capability, and in fact, on floats, where performance on takeoff is really noticeable, there were a lot of places I took the Husky that I simply wouldn't take a Cub. At least not a 160 CUb.
