Hello all,
I've had a set of plans for a Wag Aero 2+2 project since the mid-90s, and even built a narrowed version of the fuselage back then, along with the tail feathers and gear legs. Life got in the way though when I finished Med School and had to go off to do further training. I ran out of time and a shop to continue the project, and in a moment of weakness...I sold it. That's always bothered me. A couple of years ago I bought an updated set of the plans (well, they are 2 years newer than the first version I bought), so now I'd like to try this again. I retired from practicing medicine about 10 years ago, and work from home doing software development--and also do some aircraft restoration/recovery work to help out an A&P friend.
The first version of the fuselage I built was more of a fattened pa-12, narrowed from the WA plans by 5-6" or so. This was back in the day that my wife didn't mind sitting in the back seat. Times have changed, and she thinks a 4-place configuration would better suit us. She's probably right, so that's what I'm planning to build. But I think the stock 39.5" maximum width will make things a bit too narrow, even with staggered (sliding) seats, so I'd like to widen the fuselage a bit. But the question is: How much is enough without having to re-engineer the whole thing?
I've spent a couple of weeks now perusing through every pa-14/2+2 thread I can find in the forum here, and have seen several references to people saying that the 2+2 is pretty narrow. I've seen mention of two 2+2 aircraft that have been wider than the plans: One was apparently 45" wide, and one was 1" wider. I was thinking that 2-3" would be about the least I'd want to go, which would put the width on-par with the earlier C-182 airframes which seem to be in the 42" range. The C-172 aircraft tend to be around 40" wide--at least the older ones do, which is what I've spent the most time in as a CFI. So a 3" increase to the 2+2 would give me 42.5" at the widest part, right at the forward door post.
As I mentioned, one thing I really DON'T want to do, is to re-engineer the aircraft. I plan to model all of this in Solidworks before starting the build, but I plan to keep the build pretty stock per the plans, except for adding the jack-screw for the horizontal stabilizers, and perhaps slightly longer gear. I plan to use Supercub-style (which are basically per the plans), as well as pa-12 wings (with flaps). But nothing fancy though, like slats or PStol flaps. This aircraft will pretty much be used for pleasure, not back-country bush flying. We don't do much of that here in Wisconsin, so I figure a modestly widened 4-place cruiser will be plenty for what we need. Power will either be a 160hp 0-320 or an 0-360. We'll cross that bridge when we get a better idea of what the weight will be (which Solidworks will help with, to some degree). But I'm not planning to lengthen the fuselage any, or even increase the size of the tail feathers. I certainly don't plan to be screwing around with the CG envelope at all.
So I would appreciate any input you pa-14/2+2 guys might be able to offer in terms of how wide is too wide? If you had to do it all again (2+2 guys), how wide would you make it this time? I've read about people fabricating bubbled-out side windows to increase shoulder room, but that still leaves the seats in the same place, and I think I would like to have them 1-2" farther apart at least. My plan is two sticks in this thing, with the power controls between them.
Thanks much for any input you guys can offer.
TB
EDIT: I forgot to mention that I have the Northland Cub drawings, as well as all the short-wing Piper drawings as well. So in effect I could easily swap out the SC tail feathers for those called out in the plan. I'll need to compare the two sets to see what sort of difference(s) there might be in surface area(s), but seeing how you have to build a set from the plans either way...it wouldn't really make much difference which plans you used, I guess.
TB
