As I recall, all of the Dave Johnson STC's had a mandatory yellow band on the tach, regardless of crank configuration, but Dave's (sadly) not around any more to put me straight again. Could've been another Blessing from the Friendly Aviatiion Agency. I think PennYann wound up with the paperwork from Dave's son-in-law, and fixed some of the chronic issues (fuel valve position, oil cooler position); you more knowledgeable folks pleas chime in here.
I believe the 8GCBC with the 1-200 HFA-41 is yellow-zone regardless of crank. Most are probably 0-360-C2A or C2E, if failing memory is correct. Don't have my Majic Lycoming Decoder Ring on, which crank on which dash engine....
