What are the torque specs on the bolts that hold the tailwheel rim halves together? 2.80/2.50-4
5 56J Registered User Dec 5, 2021 #1 What are the torque specs on the bolts that hold the tailwheel rim halves together? 2.80/2.50-4
Grant FRIEND At Work..... Dec 5, 2021 #2 56J said: What are the torque specs on the bolts that hold the tailwheel rim halves together? 2.80/2.50-4 Click to expand... 50-70 in/lbs Here is a good guide
Grant FRIEND At Work..... Dec 5, 2021 #3 Attachments AC_43.13-1B-TorqueValues_jfpcyh.png 34.9 KB · Views: 487
hotrod180 FRIEND Port Townsend, WA Dec 5, 2021 #4 Bushwheel sez 120 inch-pounds for the wheel with BBW spacer. 3200 3400 TW Fork Kit II Intallation Instructions.pdf (airframesalaska.com)
