Gunny,
Great clarification. A year or so ago, I learned what a manufacturer of one line of new aircraft actually clears on each airplane they sell, and its about on the order of what you describe.
Ground Loop,
The EDO floats were not "tested to 2000 pounds". They are rated as 2000 floats because the fresh water displacement of one float is approximately 2000 pounds. That's how floats are rated, and it has absolutely nothing to do with structures or strength. Further, the floats were certified on the Cub by someone, Piper, I believe, but maybe EDO. That's the basis for approval, and it requires all sorts of testing, including flight test. The floats themselves are just parts. Its up to someone to STC them. When they were stc'd on the Cub, the flight test and engineering was done at 1760 pounds (don't ask me why 1760 instead of 1750), NOT at 2000 pounds. To increase this to 2000 would require engineering and ensuring that all structures and fittings would take the guff, then complete flight test. That is many dollars.
When EDO went to certify their 3500 amphibious float on the Cessna TU 206, the FAA required them to do a full certification flight test and engineering certification, even though the aerodynamically identical U 206 was already approved on these floats. This involved over 100 spins in the TU 206, by the way.
The FAA shouldn't "favor" one manufacturer over another? Good grief, ever hear of the US Patent Office? How about copywrights? The government protects individual companies' proprietary rights all the time.
You don't seriously think the music industry is going out and arresting people for sharing music over the internet, do you? Its the govmint, Dude.
Your government example has nothing to do with the discussion at hand.
