Darrel Starr
Plymouth, MN
Thought you might want to see the results of taking two 0.063 inch thick washers out of the relief valve in the O-320 Lycoming in N18SY. Tim Hieb @ Bolduc Aviation, Minneapolis, said that two washers would equal a 10 psi reduction, I got an 11 psi reduction --- pretty accurate prediction. See attached before & after pictures. Ain't iPhones great?
In a previous thread, PerryB suggested that I should knock down the oil pressure to the middle of the green and I agreed but just now got around to making the change. I'll run it a while and into warm weather this way. I have one more washer I could remove.
