Higher oil pressure after the engine has warmed up isn't logical, is it? Well that is what happens. The oil pressure has always been on the high end of the scale on my plane. The other day I did a shallow descent to check out a potential landing strip. As I added power (only about 2100 rpm) to climb back out, I noticed the oil pressure almost hit the red line. I had a camera running. Check the indications here....its a bit grainy...edited from the corner of the picture youtu.be/5rAbOw3_ll8
Then I went through some of my older videos....and what do you know.... I have had this problem the whole time. Goes to show how well I scan my instruments. On this next video you can see the oil pressure nice and stable around 80 psi on takeoff with a cool engine. Then as the oil temp reaches 100+ or so, the pressure starts to increase and goes high again. youtu.be/Jl3BXsjVY6w I checked both the Oil Pressure Relief Valve, and the Oil Cooler Bypass Valve. The OPRV (non adjustable) spring had the right tension (read 8.92 lbs with a max allowable of 9.5 and min serv. 8.3)... so on the higher end. No washers in the housing. The ball was shiny with no wear marks. The OCBV on the other hand, had some scratches on the sidewall. Maybe from a grain of something. You could see it had made a pulsating pattern in different positions. Check the video here: youtu.be/ulJpzX3kYpM
This is what I think. The Oil Cooler has some sort of restriction. And I think it is more than just thick oil since I have been pre-heating both the engine oil as well as the oil cooler on cold days. The cooler is also covered during winter ops. And why does it happen like that? When the engine is cool the oil bypasses the oil cooler and flows easily. As the engine heats up, the vernatherm starts closing the bypass, forcing the oil through the cooler....where it meets higher resistance.
Any thoughts from anyone? The engine is an O320-A2B with the 160hp STC and the remote oil filter.
