Cajun Joe
GONE WEST
LS86 or Hammond, LA
Just when I thought I was completely ready to pass a ramp check I read the following in AOPA on line. This is impossible. Now I have to get a ruler and a calculator and check out the w/h ratios of my numbers or my insurance may be invalid since I am illegal.
FROM AOPA ONLINE:
For most fixed-wing aircraft, the marks must meet the following requirements:
Height: 12 inches
Width: two-thirds wide as they are high
The number "1" must be one-sixth as wide as high
Letters "M" and "W" may be as high as they are wide
Thickness: solid lines one-sixth as thick as the character is high
Spacing: no less than one-fourth of the character width
Uniformity: same height, width, thickness, and spacing on both sides of the aircraft.
Aircraft that had 2-inch markings displayed before November 1, 1981, and an aircraft manufactured after November 2, 1981, but before January 1, 1983, may display those marks until the aircraft has been repainted, restored, or changed.
Antique/classic aircraft: Aircraft built at least 30 years ago, or an aircraft issued an experimental certificate under FAR 21.191(d) or (g) for operation as an exhibition aircraft or as an amateur-built that has the same external configuration as an aircraft built at least 30 years ago may display marks at least 2 inches high.
FROM AOPA ONLINE:
Height: 12 inches
