Marty57
PATRON
Nipomo, Ca
I hit a snag working on my fire wall forward on my 2+2. I bought a PA12 short mount to save some time rather than fabricating one my self. When I welded up the fuselage I jigged the mount bushings up well (I thought) but as with any 4130 welding, things crept out of alignment. Hindsight being 20/20, I should have had the engine mount to use as the jig. Anyway, the mount won't fit.
Now, to solve the problem. The short mount is a lot stiffer than the lighter long mount and has a lot less flex than I anticipated. The holes are off about 1/8" on one side, of the fuselage maybe 1/16" on another, and the angle of one of the bushings in the fuselage isn't perfectly straight. What to do? I have an unused case that I can use to jig up if I need to weld up a completely new mount but ...... any thoughts on getting the short mount to work? I also have a stock long mount that has a bend upper tube so plenty to work with. What are the pros and cons to heating the mount and bending to fit? My brain screams no to that option but maybe I'm way to picky as to the ways and means of adjustment on all things Cub related. I've heard the line "built with a yard stick; adjusted with a sledge hammer" So I'm way out of my comfort zone on this one. Suggestions?
Marty
Marty
