I know it's worth whatever someone is willing to pay, but maybe you folks could give me your best guesses The airplane is not currently for sale but may be in the future.
It's a 1947 PA-12 with a narrow deck 0-320 that is high time and has various vague logbook entries. It hasn't run in more than 16 years. It's here in Fairbanks, which is relatively dry but I don't know about possible rust problems. It needs a new boot cowl as the original has seen better days. My big concern about the airframe is that the fuselage is several inches shorter from the wing root to the gear fitting on the left side so it sits left wing low. I haven't looked inside in years so I don't remember what gives with those clusters up under the panel. I flew it years ago for the current unlicensed owner and that didn't seem to affect it once we got the strut forks/washout, etc. adjusted to somewhere close to normal. (When I lifted off the first time, it wanted to turn hard left!)
Someone apparently did some work on it in the past and it seems they just covered it up with fabric. When the current owner bought it the airplane was sitting off in some trees so we couldn't tell that it had a Democratic lean. It has cub flaps and gear with four inch wheels and 25 inch tundra tires. Some sort of basic radio is in the panel but I think it might not be legal now. It has the old struts and forks with a tiny amount of play in one of the bolts or holes. It has extended upper and lower baggage areas of dubious legality. In other words, it needs everything. Considering that, what's a reasonable price should it come up for sale? Thanks, Chuck
