Run-in done for two hours @ Aero Sport Power. I have the data for that and CHT’s were better, but you know how that goes with clubs, cooling fans, etc. Not comparable. Break-in is being done on the airplane.
Correct - pitch set on the Sensenich ground adjustable for cruise. Even with that setting (pitch 6 on pin gauge) it will spool up at full throttle to 2,800 rpm after a short while in cruise flight.
Will do. Interestingly, my quick readings on the Van’s forum show that most parallel valve Lycomings do best on the A curve or a custom B curve @ -1.4 advance shift and 34 degree max advance.
Was the engine broken in on a test stand? It's clear you have a low pitch on your prop given the parameters shown. That engine is loafing. At those power settings, my IO-360 with the P-mag jumper installed will use a maximum of 8 gph with the CHTs a bit lower than yours. Install the jumper to try getting the CHTs lower.
