coxcub
PATRON
Devon, England
I have an oil leak (O320 A2B) which shows itself by droplets being deposited on the inside rear of the left cowling about half way up. I am aware of a small leak from the vacuum pump adapter and thought it might have been picked up from there by the cowling airflow and deposited on the left cowling.
However I carefully shielded that (the known leak) and did another ground run - still the cowling gets sprayed.
I also put a temporary extension on the breather pipe to outside the cowling as I thought it might have come from there - assisted by some strange airflow. - no change.
The engine and acsessories are otherwise clean.
Has anyone seen this before or have any ideas 'Whence this oil came'
Many thanks
Frank
PA18-150 G-DADG
(I'd post a picture if I could work out how to do it)
Many thanks
Frank
PA18-150 G-DADG
