I have a question. All of these new high tech batteries have some good features with demonstrations of starting engines which is a high current draw activity. Why or how do they get away with using such a small diameter wire to connect the battery to the starter? We have all always used large diameter wire for this purpose. A perusal of AC 43:13 will show the wire chart. How long will those itsy bitsy wires last when starting engines????? Are they using high tech magic wire?
Another thing which I would like to point out is that these newfangled batteries have some nice features. One of the important ones is light weight. Remember the Boeing 787 battery fiasco? Boeing has an unlimited amount of resources to certify stuff. Yet they screwed up battery 101. As I understand it, their fix is a more fire worthy battery box. There is likely more to it than this. Do we Super Cubers want to be experimenting with some of this new stuff in our fabric covered puddle jumpers? Under our derrieres? Anywhere in our flying machines? Fire in an airplane scares the bleep out of me.
Pete,
There are lithium ion batteries and then there are lithium ion batteries.
The Earth X batteries are Lithium Iron Phosphate batteries....a type of lithium ion batteries, but a different type of battery than that used in the 787. The lithium iron phosphate batteries are a MUCH safer technology, apparently, than those used in the 787. So, why doesn't Boeing switch to these safer batteries? One reason I'm sure you're well acquainted with is certification. They've certified this airplane with that battery, and changing to a "safer" battery will require a lot of monkey motion. Further, having been burned once (sorry, couldn't resist) they're likely pretty gun shy of jumping on another new technology. If I were them, I'd be waiting to see just how safe these new generation lithium iron batteries turn out to be.
As to the cabling issue, I totally agree with you. All the demos I see of these little jump start batteries have VERY short jumper cables, AND as a jump starter, they're not then subjected to a big current INPUT from an alternator right after the start. Hence, small cables work.....very short cycle. But, INSTALL one of these as a primary starting battery, and cables will be longer and you'll want to recharge with alternator.
I think installed, these batteries, like any other, should be connected with large diameter cables, like any other battery.
Maybe.
