Gordon Misch
MEMBER
Pete, yeah that's what I was thinking about. Vic, good point, ha!
Lots of issues with industrial Diesel engines. Ask Mark out in Platinum about his issues with generators for the town.
Commercial fishermen are all going back to pre-electronic engines to get away from break downs. Lots of guys missing openings due to a sensor putting an engine in limp mode, then it taking days to get to port for them to spend an hour and change a $50 sensor... and the loss of fishing is in the tens of thousands of dollars.
I don't think there is a right or wrong answer. Most of the considerations I would have is again keeping it maintained. Who can help, how long to get parts? Living in the lower 48 or Anchorage one probably has a much easier time than I do in my region of Alaska.
Electronic ignition on diesel engines? Who knew?
A long time ago in the Age of Steam there was a Beaver that had a yellow light that said "Push to Test". I'd do that for fun just to see what would happen. Might have been low fuel line pressure but don't recall. Now with these new electronic enhancements I expect there'd be even more gizmos and light show displays to play with.
Most of the electronic ignition systems (full) only will run about 20-30 minutes if you have a complete power failure.
What injection does the 363 use? I assume a Bendix variant, so mechanical?
Just a note; your backup battery needs to be sized to keep your aircraft functional for as long as you can fly on a full load of fuel.
Arizona is nothing like interior northern Canada where one carries as much gas as possible.Under what circumstances could an aircraft ever be full fuel duration from a safe place to land, assuming in-flight refuel capability is not present?
Not all mechanical fuel servos are “zero leak down” and there’s a potential for the very slight fuel pressure from a gravity feed high-wing tank leaking fuel into the cylinders.
