Lowrider wrote....
The fuel tanks are one of the areas I have thought it might make sense to go heavy duty just for crash protection, but I don't want to go to an extreme. I can't think of anything less desirable than ripping a tank open on a ground loop or something worse. I've never bent an airplane but that doesn't mean it can't happen to me. I think I'm willing to give up some weight in fuel tank construction for safety sake. Maybe I'm over thinking this fuel thing.
Lowrider...I agree....seem like more than a few Cub wrecks where fuel gets spashed around....at least when you are experimental you can use modern technology to build more crashworthy fuel tanks, lines, and sediment bowls like STEVE'S.....
Also..there is fuel resistant foam that is installed in the tanks to keep the gas from sloshing around in a wreck....maybe somebody else on the site has built more crashworthy Cub tanks.
Here is an excerpt that I cut and pasted from a study of agricultural aircraft wrecks involving wire strikes speaking of the fire potential..
Wish I could get the text into a smaller space...just scroll down to read it....
Randy
Specific problems such as the postimpact
fire potential, specifically related
to the PA-25, were addressed. Extensive
studies (Department of Civil Aviation
[a]) were undertaken by the Australian
Department of Civil Aviation-now the
Civil Aviation Authority (CAA)-from
1961 to improve the fuel tank design
and crashworthiness. Many proposals
were put forward with, among others,
the insertion of a flexible rubber cell
within the existing fiberglass tank,
which was granted approval
in 1965. A
subsequent analysis of accidents
between
1974-1980 revealed that both
Piper and Cessna aircraft displayed
high post-impact fire rates (17% and
19.6% respectively), more than twice
that of the overall rate for CA aircraft.
Moreover, both showed increased fire
rates following a wire strike accident
compared to other types of accidents.
SASI
5
However, it was noted that the fire rate had improved with time for Piper aircraft, reducing from 24%
between 1969-1973 to 17% between 1974-1980. A further review of Piper aircraft accidents between 19691986
revealed that the post-impact fire rate on aircraft without the fuel cell was 65%, whereas that of aircraft
with the fuel cell was 38%. Following this, Piper Aircraft Corporation issued Service Bulletin SB 878
in
1988 making the rubber cell installation mandatory.. Also, late in 1988, a concession was granted by the
CAA to install a new improved crashworthy fibreglass tank.
