I didnt see this posted before, so apologies if it has been, but cubcrafters emailed me a note on their new 2300lb stc. Details on website but:
All PA18 series aircraft are eligible to be modified so that the aircraft
can operate legally at 2300 Lbs gross weight via CubCrafters STC
SA01633SE. The new STC allows for useful loads of over 1,100 Lbs on
wheels and over 800 Lbs on Wipline amphibious floats.
The new 2300 LBS gross weight increase STC is applicable only when the following STC’s and/or other
requirements are complied with:
1. Engine • SA92NW, CubCrafters 180 HP Lycoming engine installation
2. Wings • SA00275SE, CubCrafters Vortex Generators, AND;
• Your PA-18 wings reinforced for 2300 Lbs by CubCrafters, OR;
• SA01350SE, 2300 Lbs replacement wings
3. Fuselage • Certain existing Univair fuselages reinforced for 2300 Lbs, OR:
• SA4095NM, CubCrafters 2300 Lbs replacement fuselage
4. Landing Gear • SA00411SE, Cub Crafters 3” extended landing gear, AND;
• SA01158SE, Cub Crafters HD tail wheel.
5. Floats • Wipline 2100A floats are approved when installed in accordance with Cub
Crafters drawing TC10400.
INSTALLATION
INSTALLATION
