Hi All,
I'm slowly picking away at some issues discovered with my newly acquired J-3 Cub. I decided to pull the carb. and send it to Uni-Tech for rebuild as it seemed to be leaking fuel on the hangar floor not related to the primer. Anyway, after removing the airbox, I found that the shaft is very sloppy due to wear. I see that Wag Aero has a rebuild kit that adds riveted end plates holding bearing and a new shaft. What I don't get is that the butterfly in my existing box is brazed to the shaft and cannot be (easily) removed. How are you supposed to attach a butterfly to the shaft included in the rebuild kit? Any other ideas for fixing my current airbox?
Thanks!
John M.
Thanks!
John M.
