frequent_flyer
Arizona, USA
uAvionics AV-30 allocates one pin for reception of a GPS RS-232 bus. There is a power ground pin but no signal ground pin. The AV-30 will be connected to an RS-232 port of a Garmin GNC 355 which allocates separate pins for TX, RX, and ground for each RS-232 port.
I have suggested to the person making this installation that he should use shielded twisted pair with GPS TX to AV-30 RX, GPS RS-232 ground spliced to AV-30 power ground, and shield connected to shell at both ends.
RS-232 is quite tolerant and I expect the installation would work with a single unshielded wire between GPS TX and AV-30 RX pins. They share airframe ground. I would not want to wire it that way.
What would be best practice for wiring this interface?
