I posted some shots of my 2+2 to my album "dan2+2" if you care to look. Please comment on the elevator control system. One mod I believe I will do is to add bushings on both sides of the front pulley mount so the thru bolt is bearing on more surface. And replace the rope with steel cable so you don't have to point that out since I figured somebody would not be able to resist it. Also do not worry about hurting my feelings if you see something that will affect the safety aspect of my plane please point it out as I can correct it now more easily than after the cover is on.
