Farmboy
MEMBER
Middlebury, VT
Quick story for those techs with 0-470 experience that perhaps have ideas.
182 with O-470, ran great albeit with a few older oil leaks and plugs. Did some avionics work and after completion flew the aircraft for an 30-40 minutes and all good.
Next day was doing an extended low rpm (idle - 1500) ground run verifying further avionic improvements when suddenly it nearly stalled. I caught it with the throttle and pumped it back to life as if it was running out of fuel. Checked tanks and selector and all good. Would only run now over 1500 RPM. Mag checks were normal.
Pulled carb heat and this allows careful rpm operation close to 1200 rpm but not below. Acts like full of ice or seriously lean. Pull the mixture short distance and kills the engine.
Checked fuel for water, all pure.
Put it away for the night thinking it may be ice as the carb was cold and no heat at idle rpm.
Ran it again a day later with same problem.
Acts like an induction leak. Runs great over 1500 RPM right to full power. Will start sliding wheels locked across the grass.
All induction system rubbers checked for obvious leaks, blowouts, and clamp tightness.
Cross over tube pulled and inspected inside.
Stuck a boroscope into carb intake to see if something was sucked into the carb.
Engine has a 6 cylinder primer system. Disconnected primer feed line to check for leak/dribble. Have not capped all six lines at the cylinders.
Engine has a backup vacuum line off the intake for instrument air. Removed from check valve and plugged.
Test ran again, no change. Mags still check fine as well. Carb heat improvement there but not as much without cowl installed.
Pulled top plugs and verified plenty of compression and plugs working, just to eliminate as variable.
Seems like are at the point of dropping the carb.
Anyone got a smoking gun idea?
pb
pb
