I am building a PA-11 replica with a C-90-12f, and I would like to receive comments on what I am planning for the fuel system.
My tanks hold 15 gal. each, with front and rear outlets and vented caps ( 90 degrees forward). Using only the rear outlets and capping the front outlets, I plan to run the aluminum tubing (3/8) around the rear windows, and for the left tank, along the fuselage, below the window then to the fuel selector. The right tubing would cross the fuselage at the end of the baggage compartment, then run parallel with the left side fuel line, to the selector and down to the firewall and fuel strainer. I do not plan to use header tanks.
Any comments or suggestions will be greatly appreciated.
GDKL
GDKL
