Rob, This is an example of what you said. Notice how the engine thrust line of this airplane is set just above the wing. This is ideal for accelerating a wide swath of air over the upper surface of the wing.And while I realize moving a segment or air across the wing faster creates more lift, at the lift off speed of most of these light weight buggies, it seems to me getting a wider swath of air across the wing would get you airborne sooner.
When ready for departure with the brakes on, the flaps down and a brisk wind, applying full power provides enough lift on the wing to extend the shock struts to their full extension. Without rolling a wheel.
I try to let other pilots determine what they think is the best procedure for them in any type of event.Which surely means that all that thrust that is producing lift is not available for acceleration. If producing static lift was so advantageous why do the hot STOL pilots delay flap extension until rotation? Answer - they minimize drag to get maximum acceleration to rotate speed and then, and only then, do they increase lift.
That is an interesting observation. And here I thought it was a simple case of monkey see - monkey do.
Have you ever flown in a breeze enough to rotate from a standstill? Would you still leave the flaps stowed and go blistering down the strip?
If shortest takeoff was achieved by lowering flaps at rotate speed then wouldn't flap go down at zero speed in this case? After all, you are saying rotate speed is zero.
It could well be monkey see - monkey do. I have no aspiration to be a STOL winner and I set my flaps before setting the power.
I bet this is a really nice plane! You’re brave to put it on here tho, cause there are some haters here. Not all, but some are loud, cynical, cry babies. Full of, “I” this and that. Lots of babies in the sand box, “my toy is better” blah blah. Nice to see some innovations like what we see here in this cub!I finally got some hands on time with the Norden and let me tell you it does not disappoint!
View attachment 58554View attachment 58555View attachment 58556View attachment 58557View attachment 58558
Other then pictures, I’ve not seen a Mackey Aircraft in person so I’ve no way of verifying wether or not your assessment of “innovation” is correct. Or not. A “scale” or not, how would I know?Innovation? It’s a scale model of a Mackey SQ-18 with some minor tweaks, like electric slats, and that’s an innovation most bush fliers wouldn’t want. Time will tell whether it makes an impact or a quick exit.
That being said I'm sure it's a fun to fly little plane. Not the most practical for any "serious" use but a fun toy.
The SQ-18 DOES NOT have slats, it has slots! The Shock Cub? Slots! The Norden is the first GA aircraft to feature electric retractable slats. That is called innovation. Don’t have a clue where you got that Carbon Concepts “slots” were “electric slats.”
I ran lots of PL and WL numbers when I was deciding what plane to build and why. These are derived from manufacturer's specs. The only honest empty weight report is by BCSC.
Just SS XL wing loading empty- 6.8
gross- 11.75
power loading empty- 5.0
gross- 8.16
Carbon Cub FX3 WL empty- 5.23
gross- 10.84
power loading empty- 4.83
gross- 10.02
BCSC Rev 2 WL Empty- 6.47
gross- 10.7
power loading empty- 6.17
gross- 10.2
Stock Supercub 1100#/1750# @150hp
WL empty- 6.16
gross- 9.8
PL empty- 7.66
gross- 11.66
For grins, how does my own 180 stack up?
WL- 10.34 empty
18.33 gross
PL 6.54 empty
11.6 gross.
I defend innovation and get frustrated when it falls on deaf ears. Mark my words you’ll see this wing planform copied many times in the future.
I think that's exactly what I thought of the J3 when I first flew one.
