Short take off even with a tailwind.:roll:
Haha sarcasm? They still aren't pushing the envelope and only used the first notch of flaps here. When they install an EPeX400Ti later this year it'll be a rocket ship!
Nice tufted wing video (and flaps). Too bad speeds aren’t shown.
https://www.instagram.com/p/CBBTD9EBQVd/?igshid=biftgm6o40p3
Those are the latest frise ailerons they were testing as well. Roll rate looks great. I’ve never seen such smooth airflow over the entire length of the wing at such a high AOA.
In their latest video the Czech pilot said he was flying at 15 mph that day. I’m sure that’s where they are at in that slow flight portion.
I wonder what type of instrumentation they are using to determine that speed? 15 mph is not very much....In their latest video the Czech pilot said he was flying at 15 mph that day. I’m sure that’s where they are at in that slow flight portion.
Look at the windsock at 2:55.
What did it weigh before the rework?
I don’t know the exact number but it was around 930 pounds as it had a parachute, ACME’s, ACME stinger with the baby bushwheel, etc. I think a well optioned LSA Norden with 26” Airstreaks could come in around 850 pounds with ACME’s and a T3 tailwheel.
I'm really curious to see actual weights. Knowing what an 850lb plane looks like and how few items you can have on such a plane and then seeing the Norden with all the gizmos and slats...something doesn't add up.
One of my neighbors is getting one of the first 5 in the US. Looking forward to seeing it
Factory build, or a kit? When do they expect delivery?
An engineer who I respect told me long ago that the most efficient propeller has only one blade. Each additional blade is operating in the wake turbulence of the preceding blade. The main or perhaps only reason for more blades is to harness the horsepower from the larger engines. Of course there are other reasons more technical in nature. Also the larger the diameter, the larger the mass of air is "pushed" back creating more thrust. The diameter is limited due to clearance needs or tip speed limitations. A long slow turning propeller is the most efficient.I have read at times that 3 blade props look cooler… to me a giant 2 blade prop is more pleasing to the eye
