Well, I'm still working on it and I've blown pretty much every estimate of how long I thought it would take. Eventually got most of the engine area planned out so pulled the engine and the gear and covered the fuselage. I have one issue with my b&c alternator which doesn't seem to fit. It contacts the oil filter adaptor before it seats on the pad.
Jay puts the same alternator on the same engine and it seems to work. I got my engine straight from Titan so I suspect there is some difference. I also still need to figure out my cooler config.
Everything is covered and silver coated. I'm frantically trying to get the major portion of painting done since the temps will be too warm inside of a month. Mornings are still OK, even most afternoons but that will soon change. So far, the tail feathers and the fuselage are painted. It is a massive task. Here's the basics. First, put the fabric on, stitch. tape and reinforce, and get all the shrinking done. Then paint all the exposed fabric with diluted glue to seal the weave. Next, silver coat and you don't want to wait too long since the glue is tacky and will collect dust. Three cross coats of silver, sanding after each coat. Then, because I'm mostly yellow, a fog coat of white primer and then enough to make it pretty evenly white, sanding after each coat, of course. Then yellow in four coats waiting only long enough to tack and starting very light adding a heavier coat each time. So far, it's turning out acceptable and is about a 10 - 15 ft paint job. I have only a few runs.
Here are the stages in photos.
Cleanup takes a couple of hours. The silver and the white primer are easy-peasy but the two part epoxy is a bear to get off my gun and I often have to resort to a solvent other than water. .
As soon as the painting is to an acceptable point, I will start final assembly from the tail moving forward. A lot of the tail and under the floor was already done before I covered it.
Wayne
