Use Rutan Bi-directional 7725 cloth. I think is 8.8oz fabric. google 7725 fiberglass and youll see its common. Spruce has it. Cutting on the bias means cut it on a 45 degree diagonal. If you are worrying about waist when you cut it off the roll your doing it right.Thanks, guys. Do you use something like a 10 oz cloth or what? How do you finish it? Gel coat or just fill and sand or something else?
Wayne
Finishing it....
You would get a lot out of going to EAA Sport Air Workshop "Composites for Vans Aircraft" class taught by Scott VanderVeen. If you go to it you'll do this task in class and have a stronger lighter windshield fairing. I cant do it justice using this type of communicating.
But you asked.....when you order your cloth buy a pound of flocked cotton and a pound of glass bubbles aka micro balloons. Micro Balloons aka Micro is like dust particles of glass beads. So use a mask, do not breath it in. Mix up your epoxy like you lay up some glass cloth, then start adding in the Micro. it will take about 5X volume of Micro to Epoxy. ABout 5.5OZ of Micro to 1 pump of West System Epoxy. mix in a little at at ime until its like cake frosting and the tips of it done fall over. We call the mixture of Epoxy and Micro Balloons "Dry Mirco" when the mixture has so much Micro that the mixture looks dull for 3 to 5 seconds after you stop mixing it.
Now frost your window fairing like your frosting a cake and let it cure. 8 hours at 70F or 3 hours at 120 F if you can get it warm. Then sand it with 80 grit and the corner of a small block of wood as your sanding block on 45 degree pattern across the line of the fairing.
I attached a photo. I did this last week. Its not for the windshield. I'm modifying a vans cowl scoop to fit my cowl. I first fabricated a sharp fillet of 50-50 ratio of Flox and Micro mixture becuase Micro is not structural, Flox is. But flox wont sand much at all, Micro sands fabulously. I then immediatly applied two layers of Epoxy impregnated cloth over the fillet let it cure. Then I applied a 20-80 ratio of Flox - micro over the top of the sanded glass cloth to form a gentle fillet and immediatley applied two more layers of glass cloth. Let it cure. Then I frosted it, sanded it, and did it two more times to get it looking good. I dont have a photo of that part handy.
If you dont sandwhich the fillet then I'd use more than 4 layers of cloth. Bob Barrows calls for 8-10 layers for the Bearhawk Patrol fairing. I bet the sandwhiched process is lighter and stronger and and better looking.
