Jim Miller
Normandy TN
My Clipped-wing project using Colt wings needs special length struts that I am trying to
make. I wanted to have them as long as possible to use max number of fork threads.
I have made one side and may have made the rear too long. I need some advice on how
to position wing for a good measurement. The wing is on with the struts holding it up. The
main (Front) seems OK (Not too long) because with the front spar carry thru tube leveled the
wing tip end is below level meaning I need to turn out fork to raise. How should I position
to measure rear strut? Is desired wash-out about 1 1/2 inches (up at the tip)? What do I level with what before adding in the 1 1/2 inches? These may not even be the right questions to ask but hopefully enough for readers to understand the problem.
Jim Miller
Jim Miller
