I was watching some of the 10 year anniversary videos about the Carbon Cub. Obviously it is awesome to have such a great plane continually improved as the Carbon Cub is along with a great kit and good support.
My question is, what makes a Carbon Cub like the EX-3 version that is out now so much lighter than an equivalent Supercub? The EX-3 has a 2000lb max gross weight and a Supercub can easily have a 2000lb max gross weight. How does Cubcrafters get 150+ pounds out of the plane compared to a Supercub at the same gross weight assuming, the same bush wheels, avionics, O-320 base for the engine(obviously CC gets more power), etc. The EX-3 has a constant speed Hartzell propeller that is heavier than the typical fixed pitch Supercub and the EX-3 is fuel injected. I know the EX-3 has a magnesium accessory case and an aluminum sump but that is not 150+ pounds of weight savings. Cubcrafters claims 50% fewer parts than a Supercub.
