I wanted to get some solid feedback based on experience regarding welding 4130. It seems there are many opinions on the subject. As a mechanical engineer I can appreciate the metallurgy involved. The heat treatment of steel, both intentionally and unintentionally, is a well documented and time proven process. You really can't argue the fact that when 4130 is heated above it's critical temperature and then rapidly cooled, the crystalline structural of the material is changes resulting in a very hard (but brittle) steel. Subsequent tempering by reheating can then relieve the inherent stresses, reduce the hardness and brittleness, and make the material more crack resistant. The questions are:
1. Are we heating the steel tubing above the critical temperature?
- I would certainly say yes; at least locally where the molten weld puddle is.
2. Does the steel tubing in our aircraft cool at a rate which causes this to happen?
- Questionable. Depends on the surrounding structure, tubing thickness, ambient air temperature, and ambient air flow.
3. If brittleness is the result, does it really matter in our fuselages?
- This is a matter of debate. People generally think of most tube fuselages as being over-designed. Engineers typically design in a "factor of safety" which is some multiple of the stress which is actually expected. Then of course some joints may be brittle and others are not depending on the conditions listed above. I can tell you this, if given the choice I would rather fly in an aircraft with welds that won't crack!
So what have all of you experienced? What welding method do you employ (Oxy-Acet or TIG)? Do you heat the weld afterwards?
Here are some links to info on the subject (with conflicting information):
http://www.netwelding.com/Welding 4130.htm
http://home.hiwaay.net/~langford/sportair/
http://www.tigdepot.net/articles.php
http://www.eaa1000.av.org/technicl/4130.htm
http://www.lincolnelectric.com/knowledge/articles/content/chrome-moly.asp
