Hello faithful cubbers,
I have more documentation than you could haul in the plane!!!! Starts back in 1949 to current. I have a PA 18 150 "equal" the logs say so.
Needing help with the weight and balance as I believe my #'s on the ones I have been attempting are not correct.
The weight X Arm equals moment.
Start with an empty plane. 1141# and moment is given on 1993 weight and balance data sheet of 16,380. Add a pilot 235# X 71", passanger 150# X 97", baggage, 50# X 117, and fuel 180# X 74". This equals a great big number. A total moment if you will.
Divide total moment by total weight and subtract out Empty Weight Center of Gravity and compare to your graph? Weight up the vertical and inches along the bottom.
I'm out of CG?
I'm out of CG?
