djfraudman
Meadow Lakes, AK
Attention; Mat-Su Pilots and Airstrip owners
Wasilla is attempting to modify the airspace in a 5nm circle around its airport from uncontrolled Class G to Class E airspace beginning at the surface and to establish a precision approach. This is allegedly being done because of greater demand of use and services at the airport. (See attached letter from the City)
There are over 30 private air strips within the proposed Class E airspace and everyone using one of those strips or transiting the area will be affected because you will no longer be able to enter or leave Wasilla’s airspace unless the visibility of more than 3 miles and the ceiling is 1000 foot or above. If the visibility and/or ceiling is less, then you will need to get a Special VFR clearance.
Since most of the people impacted by this proposal are not Wasilla’s residents I doubt the city will be responsive to their concerns and I have been told by people who called the author of the city’s letter that he didn’t appear to be interested in what they had to say. A friend contacted the FAA concerning Wasilla's letter and was advised that Wasilla has not yet formally presented their proposal. If and when that happens the people affected may have an opportunity to be heard by the FAA.
I’m sure there are Supercub.org readers who have thoughts about why Wasilla is on this boondoggle and will share their knowledge.
My suggestion, if you are concerned, would be to contact Borough, State and Federal elected officials and express your feelings about Wasilla’s push for an “approach to nowhere”.
